Comment
Guide Tools
<!-- google_ad_section_start -->Front disc change<!-- google_ad_section_end -->
Front disc change
Published by Andy Monty
28-02-2011
Difficulty Level: 4
User Rated:
Difficulty Level: 2
Front disc change
This is intended as a guide only if your in any doubt over you ability to do this consult a qualified mechanic as your brakes are rather important
bit of an add on to this guide as im not going over the intimate details of pad removal again for the sake of it
http://www.fiatforum.com/grande-punt...rip-clean.html
So car parked safely wheels chocked hand brake applied
car jacked and axle standed and front wheel off
remove the caliper piston body using a 13mm spanner as in the above guide and the pads (if your new pads come with clips look how the old pad spring clips fit as they only fit on one way)
clean the piston
clean then remove the brake fluid cap off the header tank
((DO NOT SPILL ANY FLUID ON YOUR PAINTWORK OR IT WILL REMOVE IT))
next reset the piston ensuring you do not damage the rubber piston seal boot
i used a g clamp but you can get a special tool to do this from most motor factors
do this slowly to give the fluid chance to move back without putting any undue pressure on the seals
now i have dropped a bo bo here and not got a photo of this step but i will try and get one when i get chance
you need to undo the caliper carrier using a 19mm socket and remove the 2x bolts
so this bit comes off
now you can get the disc off
using a T30 Torx bit undo the 2 torx aligning bolts these are commonly seized in so a bit of release oil might help and in my case a hammer and impact driver
once both are removed either the disc will drop off with a slight pull or need braying round the edge with a hammer to crack any corrosion
clean the stub axle up and coat with copper grease (makes changing them next time easier)
now get your new disc and clean it well with brake cleaner (they come coated in light oil to prevent rusting in storage)
and refit
apply copper grease to the threads of the torx bolts to make removal easier next time
refit the caliper carrier putting a drop of threadlock on the bolt threads for added security
then fit the new sping retainer clips and new pads greasing the back of them lightly (on the piston side the other side bonds in place with a sticky pad so degrease the caliper where the pad will stick
ultimately you will be left with this
19mm caliper across flat carrier bolts Torque 9.9 11.0 (daNm)
13mm across flats caliper bolts torque to 2.7 3.3 (daNm)
T30 torx bolts torque 0.9 1.4 (daNm)
now refit the wheel and do the other side
check fluid doesnt over flow as you reset the piston
once the other side is done pump the brake pedal slowly with the cap off to reset the pistons then refit the cap
now start the car and pump the brakes and check they feel ok
now do several low speed stops in a quiet area to check all is working as it should
AND IMPORTANTLY DRIVE WITH GREAT CARE FOR THE FIRST HUNDRED OR SO MILES OR SO TO GIVE THE NEW PADS AND DISCS TIME TO BED IN AND GET TO FULL POWER AS YOU MIGHT FIND THEM LACKING IN BITE FOR A WHILE i know of a chap who stuffed his car into the back of another having just had his brakes done so it can happen
Thanks derbyshire gp, Brad Cogan, Ryan13, jackgoughblah thanked for this post
Likes derbyshire gp liked this post
Old 06-11-2011   #1
Egypt
Re: Front disc change
I Like this post
I did try it my self and it worked fine
Thanks Andy Monty thanked for this post
Likes Andy Monty liked this post
Fadi Ayad is offline Reply With Quote Quote
Old 08-11-2011   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Welcome to the forum Fadi
Massive gash
Just a little touch up
Old 14-05-2012   #3
Its Not Just A Grande...
fatti1477 has donated!
Anyone Else had problems trying to Undo the Aligning Bolts, Mine seem to be Chewwed and won't come out, Any ideas?
Grande Punto 1.2 Active
Ice Hockey
fatti1477 is offline Reply With Quote Quote
Old 15-05-2012   #4
Moderator
Andy Monty's Avatar
drill them out if the heads are gone use a 8mm ish drill bit dead centre just drill far enough so the head falls off then remove the remaing stud with mole grips......
i got mine out using impact driver
Massive gash
Old 04-12-2012   #5
Chile
What brake discs and pads do you recomend? (im gonna buy them on ebay.. here in chile I could only find korean and chinese ones )
great guide btw
How about these? http://www.ebay.com/itm/FRONT-EBC-UL...item5d34d9a420
GP ACTIVE 1.4 8v 77hp (hell's ponys)
etche is offline Reply With Quote Quote
Old 06-12-2012   #6
Moderator
Andy Monty's Avatar
watch for fake ebc discs and pads on ebay...
http://www.ebcbrakes.com/cross_drill...d_rotors.shtml
Massive gash
Old 15-01-2013   #7
when im changing discs and pads i back off the pads with a big flat head screw driver before i start taking the caliper off.. remember to open your brake fluid reservoir and maybe put some old throw away rags around the opening because the fluid might come out fast
i only do this when im changing the discs aswell because i might mess up the disc when i use this method because im levering a screw driver with it
keepfixinit is offline Reply With Quote Quote
Old 06-02-2013   #8
hi, i have to do this job on my sisters grande punto but i've looked for the parts on ebay and they say that there are more than one type of disc fitted to this car (vented or solid) and i cant check it until she drives it to my workshop. its a 1.2 8v active 2007 on a 07 plate. could someone tell me what discs are fitted? thanks
Old 06-02-2013   #9
Moderator
Andy Monty's Avatar
don't know the change over date my 06 came with vented.... Will the factors let you order both on sale or return?
Thanks keepfixinit thanked for this post
Likes keepfixinit liked this post
Old 06-02-2013   #10
yea they will but i cant really afford to buy 4 disc and i have to go thru the hassle of sending them back without damaging the boxes i think ill just have to have it here for 5min and check why dont they make it easy and fit one type of discs to a 1.2 instead of making it a mission find out thanks for your help anyway mate
Old 06-02-2013   #11
Old 18-08-2013   #12
AB2011 has donated!
Does any one know the disc thickness that should trigger their replacement? Or is there some other rule of thumb that can be used to indicate that they are due for replacement? You don't just change them when you renew the pads, do you?
AB2011 is offline Reply With Quote Quote
Old 18-08-2013   #13
Moderator
Andy Monty's Avatar
There is a disc wear indent on the edge of the disc rotate it looking at the edge of the disc and you will see it
Old 04-10-2013   #14
Tried getting discs off but caliper fixing bolts look as if they need a special tool ,nothing like any spanners i have and have been fixing cars for 50 years. Any ideas please?
DavyP is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bravo 1.6 Sx Front Disc And Pads Change donnabravo2k8 Bravo / Brava 2 22-09-2008 09:26
(T) Front disc and pads change Rustymini Doblo 0 16-09-2008 18:38
(T) front disc change Dougiebob Multipla 6 07-09-2008 21:43
(T) Disc change 48POP Cinquecento / Seicento 12 21-12-2005 18:13
