The FIAT Forum
Old 25-09-2006   #1
...done
Trader Rating: (1)
mase has donated! United Kingdom
water pump renewal
right then, time for a new water pump me thinks, the cento uses water slowly but surely and there is a strange whistle / whine coming from the alternator / water pump area, and as the water pump is cheaper, i am going to change that first
so people who have already done this, anything i need to look out for?
and is there a gasket that i will need as well?
and im guessing its easier to drain the coolant before attempting this?
cheers
mase
R97 cinq 1242 <Ex Team Anthracite >
(now sold)
mase is offline
Old 25-09-2006   #2
99sei's Avatar
Trader Rating: (1)
99sei has donated! United Kingdom
Re: water pump renewal
cant answer any of your questions, but a photo diary would be nice
Originally Posted by 99sei
im ginger and special
and now im terrorising the roads in my cinq
99sei is offline
Old 25-09-2006   #3
...done
Trader Rating: (1)
day 1, Monday 25th sept 2006: raining outside, woke up to sound of rain against window, decided i couldnt be assed to get out of bed, so didnt, water pump can wait.
that sort of thing?
few other random questions as i cant be assed to find the haynes manual.
1. do i need to take alternator out to get to water pump?
2. if so would i need a new alternator belt?
if answer to number 1 is yes, then your going to have to wait, as im plannin on fitting an uprated alternator as well but not gettin it yet.
(now sold)
mase is offline
Old 25-09-2006   #4
The Thrill of Driving....
J333EVO's Avatar
Trader Rating: (0)
J333EVO has donated!
The water pump is fairly straight forward to change, but you need to remove the cam belt first as this drives the water pump, so may as well replace the cam belt and alternator belt unless both are fairly new and known to have lots of life in them still.
There is no gasket supplied with pump, its an instant gasket you use, do not use the blue or red universal stuff, use the Loctite specific one for water pumps, its either grey or black i can never remember as one is for sumps one is for water pumps but they are both found in Halfords.
It may also be useful at this time to check the seal on the pipe that goes from water pump along front of engine as the rubber O ring can compress over time and leak, these are available from Fiat for less than £1 so no need not to change, Fiat have actually updated this pipe to a better design with a large rubber sleeve that can't compress over time, and therefore not leak, but its £20ish. You do not need any gasket on this pipe the rubber O ring seals fine as is, if its got sealant on it its probably leaked at some point seen many like that.
its not a hard job at all, just a bit time consuming.
Aaron.
1992 Lancia integrale EVO1;
1995 Toyota Celica GT4 ST205;
2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's)
J333EVO is offline
Old 25-09-2006   #5
...done
Trader Rating: (1)
Aaron.
cheers dude.... it had a new cam belt when the engine went in (i assume) so its done 20k tops.
if i just slipped the cam belt off the water pump housing then fitted a new one, would i need to get the timing looked at after?
(now sold)
mase is offline
Old 25-09-2006   #6
J333EVO's Avatar
Trader Rating: (0)
Just set the timing up before removing belt its not difficult, line the mark on cam pulley with mark on head, and the crank pulley with mark on block, if you have a Haynes manual it shows you how to do this, I would't just slip belt off anywhere and hope you get it back on correct place again, to easy to get it one notch out.
And are you sure the pump is on its way out? the noise you here isn't just the alternator belt slipping? or the rubber O ring i said compressed as when this happens water leaks out of pipe/water pump join and runs down body of teh water pump making it look like its the pump thats leaking.
J333EVO is offline
Old 25-09-2006   #7
...done
Trader Rating: (1)
im not sure at all TBH.... its very strange
it does make a slightly weird noise, which varies in volume, i think ive narrowed it down the to alternator or water pump. well at least thats the area its coming from, the alternator belt doesnt seem loose, and im not gettin any power loss when its under load, though the belt does squeel occasionally after heavy rain.
but coolant is being used up somewhere, its only a very slow leak, and there is never any drips left on the drive / car park over night, so i thought it was either the alternator belt or the bearings in the water pump?
but thinkin about it, suppose it could be a slightly loose alternator belt, and that o ring u talked about.... guess i need to take the car apart and find out, bloody over time.
(now sold)
mase is offline
Old 25-09-2006   #8
Trader Rating: (0)
After my recent headgasket shenanighans, im looking into replacing the water pump meself soon. Will be watching this Mase "diary style" thread with interest.
woodins is offline
Old 25-09-2006   #9
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
To discern whether the alternator bearings are at fault, take the alternator belt off and start the car. Yes the red light will be on, but it does no damage to the alternator or battery to run it like that for a few minutes.
D
rallycinq is offline
Old 25-09-2006   #10
...done
Trader Rating: (1)
D
i was about to ask weather something like that could be done to determine which was cause the weird noise!
(now sold)
mase is offline
Old 25-09-2006   #11
rallycinq's Avatar
Trader Rating: (1)
Its not often I can be proactive rather than reactive.
D
(T) Punto Cabrio 1.2 16v water pump faulty Scooterck Punto 1 02-03-2006 09:48
(T) Water pump / cambelt change deeqsei Cinquecento / Seicento 3 25-02-2006 00:31
(T) 55SX - Not starting after water pump change Symmo Punto 5 27-01-2006 23:00
(T) Sei loosing coolant - water pump? Hallsy200sx Cinquecento / Seicento 2 23-10-2005 13:30
(T) Water Pump major leak red_cinqo Cinquecento / Seicento 2 25-10-2004 23:10
