Hi all.
I've got a strange issue I've never noticed before.
My car has had completely new front suspension (Everything replaced except the driveshafts & rollbar)
I've made the assemblies with various component brands.
It looks to me that the D/S wheel is further inside the wheelarch with a bit more camber. It also looks lower on the D/S?!
The car drives fine (except the PAS working on one side) and it tracks ok, not really pulling to either side with the wheel straight.
I had an interesting problem when I bought the wishbones. They came from the same supplier and they were both patent FAI brand, however they had completely different finishes and were slightly different lengths by about 7-10mm!!
I returned them and changed suppliers. The replacements came and were the same quality finish and the same length.
I got the uprights/hub carriers used from a breaker, had the bearings and hubs pressed out, then blasted and painted them.
Dampers are new Hart gas struts and springs are brand new Eibach Pro's and appeared the same length when I built them off the car.
The rear suspension is pretty knackered except for new Hart dampers and Eibach springs.
Is it possible that either of the hub carriers are bent at the 2 strut bolt points or that the wishbones are meant to be different lengths?
Will I only get answers from a professional lazer checkup?
Anyone had this done? ££?
