- May 11, 2016
- 37
- 10
So I just saved a Cinquecento from the scrapyard.
Fresh APK (Dutch MOT), 2 months old head gasket, 99 pounds.
I was looking for a cheap runabout (no worries, I actually will take care of this little car) second car so the timing was perfect.
It drives well, except from some sticky brakes after heavy braking.
But once it gets up to temperature, it seems to go into some sort of emergency mode running rough and revving very slowly.
There's a light (injection?) burning on the dash. See attachement.
I've only driven it for 10 minutes and when warm so I don't know whether the light is on continuously, or comes on once the issue arises.
The owner said that it starts when the car comes up to 90 degrees celcius. It takes longer for the problem to begin in wintertime than in summertime.
Apparently as soon as it reachtes these 90 degrees the temperature drops to 70 degrees but the problem stays.
Acceleration is really slow, even when in neutral, top speed is around 60mph/100kph and the car smells of unburnt petrol.
You can actually search for "ZmkRgVTYQL0" on youtube. It will give you a (Dutch and rather chaotic) video I just shot and you can hear how slowly it accelerates and how rough it runs.
Also you can hear there's a problem with the brakes after heavy braking, they seem to 'stick' a little. Probably just greasing of the calipers, I guess we'll figure that out.
It seems as though some sort of error when warming up tells the computer to put the car in some emergency mode as soon as the car has warmed up.
I hope to fix this car as it's way too nice to scrap just yet.
It's only done 130.000km (80k miles) and I hope to be able to keep it running for a year or two. I love the way it drives otherwise, it's surprisingly stable and comfortable for such a tiny light car.
If anyone has any idea what's going on, that'd be lovely!
Thanks in advance.
Thanks in advance.
