Struttycento
Hi, I need a little help I want to convert the back drums to discs and I don't know what size discs and calipers to use, does anyone know what sizes to use? Thanks
Do these fit within standard Cinq Sporting 13 inch wheels?
You need to do the fronts if your doing the rear there'd a guide on here somewhere that tells you what front brakes you can use but for the life of me I can't find it only using the mobile app atmJust had a thought on this if I convert to disc's what is sensible to do to the front
I wouldn't worry too much about fitting rear discs without changing the fronts. You won't be adding much rear brake force with the change. Fit fast road pads to the front brakes if you want a quick and easy front brake upgrade.
