Time for an update I suppose.
Good things;
She passed the MOT with flying colours, although a comment was made for the temporary headlight alignment fix (cable tied to the correct setting).
Crank and bits and pieces will be back tomorrow along with a new honing tool.
Sump has been cleaned up and will be painted.
1 of the lads I work with bought a brava/bravo which he sold the engine but does run 14inch wheels so I will be pinching the brakes from it as long as they will fit.
Bad things;
Still no cam so going to be enquiring about that tomorrow because they are starting to take the mick
Car has developed a slight hesitation when under load however wouldn't run correctly on the way back from Cardiff, changing the fuel filter made it better but not perfect any suggestions appreciated.
So if Gazzella turn around and say that the cam will be with me in April/May time I will have to fit it at a later date as I want the engine in for Brooklands /Stanford Hall.
On a side note does the cam need a vernier pulley to run or is it possible to have the cam on the original cam pulley?
