Hi all. I'm new here and spotted this thread hoping I might solve a problem that looks similar.
I have a seicento.
The car was fine yesterday but this evening my son went out in it and drove around for an hour and all was fine until the gears wouldn't engage,
He managed to get home somehow.
Anyway, I got in the car. Started it and tried to put it in first. Clutch felt normal pressure but first gear just wouldn't go in. Then tried reverse gear slowly because I suspected clutch was maybe gone. Heard the gears grind as I tried to engage reverse so quickly abandoned that idea.
Then I cut the engine, put it in first with clutch depressed and started the engine. Started fine with car remaining stationary. Then I slowly raised clutch and car moved away normally but when I tried to move into second gear I felt resistance and it just wouldn't go into second. Stopped the car and cut the engine. Tried the same procedure but this time started in reverse gear and again it was fine. Clutch seemed to operate ok only if I do the above. Just won't engage when I depress the clutch and try to engage any gear when the engine is in tick over.
Any ideas would be much appreciated. Thanks
