Not changing coolant is a recipe for pitting a head, lotsa heads will be pitted as most little fiats are run on low maintenance, neglect...
It might skim off before reaching a interference level, but you may need to shim even if the head surface is good to get it back to flat. If you have got an unwarped and skimmed head to hand I'd use that...
Noel
before you spend some money take the head to somewhere that skims heads and ask their advice, chances are a skim will take most of that out
HiHang on. In what sense does shimming the valves (after re-cutting) have anything to to with skimming the cylinder head?
That makes me sound like some kind of freak, true enough though.But he has 2 heads already, now..............
