Hi everyone.
I have recently put my mpi seicento back on the road, however I am having issues with it. The main aside from a fastish puncture is that under braking the car will stall.
This occurs when slowing down from highish speed. I use up all the stored vacuum, and then when I put the clutch in to change down or stop then the engine will stop
I can also get it to do it when stationary. If I hold down the brake pedal down hard the engine will eventually stall.
It is like the extra load the vacuum servo puts on the engine is enough to stall it
If I keep the revs up it's ok.
Any thoughts on what it could be?
Maybe something related to idle control? How does it work on an mpi cento? Only really have experience of spi centos.
Hope someone can help,
Many thanks
Many thanks
