adavies1108
- Jun 25, 2011
- 8
- 3
Ive recently been given a 1997 cinquecento sporting that was running just over a year ago and needed a wheel bearing, water pump and new belts.
Ive replaced the water pump and wheel bearing and put new belts on lining up the timing lines as stated in the haynes manual when refitting them. I went to turn it over after putting it all together and it was just clicking and not turning over at all.
I came on here and read a few posts and from what I read replaced the starter motor.
After fitting another starter motor that i got and turning the key the enging turns over but still wont start!!!
Im getting a spark from all four plugs as they are new and I checked they were all sparking before putting them in. There is feul going into the injector unit as when I took the air box off it was wet with feul inside and im pretty sure that the timing is ok as I lined it all up as best I could using the manual when refitting both belts.
Im all out of ideas and was hoping someone might be able to help me out.
Help!!
Many thanks
Help!!
Many thanks
