Hello everyone,
I know this topic has been exhausted but maybe the variables in my situation are different...so bear with me please.
Alright, so the day before yesterday I go to this specialist and we flush the cooling system, give it a good rinse and put it back together with the coolant hose adapter for my newly acquired temperature gauge.
Next we leave the motor running and wait for the fan to kick in but it doesn't. While checking the temperature sensor connection and probably giving it a nudge it starts working so I'm off... Fan comes on normaly for a day but yesterday it stopped working again.
If I short the connector to the radiator temperature sensor, the fan come's on, so I figure the sensor is acting up and replace it this morning. Again the fan doesn't come on .. I let it boil and bleed it .. fan comes on... which makes me assume the sensor wasn't to blame for in the first place...and there's trapped air inside the radiator giving the sensor bad readings.
I drive it around for a while ..fan doesn't come on again! :bang:
I also noticed yesterday that there was a little leak on the gauge coolant hose adapter so I changed the jubilee clips with better quality ones than the ones that came with the adapter. Today AGAIN I notice some bleeding under the adapter...
What do you make out of this ? Could it be air coming from the adapter leak causing the problem ? It's doing my nut in.... I don't know what else to do with the adapter... I also screwed the sensor in really tight with teflon tape.
Any ideas ?
p.s.
The gauge looks really good fitted under the radioCD ! I will post pictures in the guide which are missing, on how to get the wire from the engine bay inside.
Any ideas ?
p.s.
