Yep, this time it's me. The engine is a 1.2 MPI turbo with lowered compression ratio by a sandwich plate, no cat. Engine runs fine, everything seems to be in order, AFRs on my display, all that. But it failed miserably on the CO test today. At idle it has more than 1.0 out of allowed 0.50, at high idle 0.80 out of allowed 0.30. They were kind enough to let me play with the ignition timing on my ECU and see if I can get it any better, but this brought me nowhere.
Now, apart from the obvious advice that I probably should put the cat in (I don't think it should fail so bad without it, or should it?), I was also thinking if I possibly have setup the vernier pulley wrong. I did everything by the book and the engine runs smooth as I said. But I could have as well messed something up, and it might be a couple of degrees off. So my question is, which way am I likely to be off with the pulley? I will get another chance for one test tomorrow, so I can try to change the pulley settings before that, I just don't really know which way. I want to change it a bit and see if that brings me anywhere better.
EDIT: Am I right in thinking that I should retard a bit, so that exhaust fumes do not start to escape so early, ?
