Has anynoe ever take the ball joint part on a cinq, I am looking to replace my front bushes the end of next week and I would like to remove both fornt wishbones from the car altogether.
From what I can understand and see I need to use a ball joint spillter to remove the threaded rod from the stub axle once the nut has been removed. Is it possible to remove the rest of the ball joint from the wishbone, also from one of my photos it looks like the ball joint has some sort of rubber boot protecting it?
I gather the ARB just unbolts from the wishbone by removing the 2 bolts, and the wishbone unbolts from the bottom of the car next to each bush. The front bush on a cinq looks to be bolted up into the car with two bolts, the rear bush looks to be connected to the car with a nut and bolt through the centre of the bushes.
Any help on this would be great.
David
David
