Hey im wondering if anyone could shed light on this issue im confusing myself with
is it possible to use the selectors off a brava on a cinq sporting gearbox even thow on the brava where the cable connects is above the centre of the shaft and on the cinq is below (picures below)
cinq on the right brava on the left
cinq top brava bottom
as im getting confused if i used the brava using i could have 1st where 2nd is reverse where 5th is etc
the reason im asking is that the brava has the extra lug in the original casting for the hydraulic clutch
if not then i could with alot of pain change the cinq internals over into the casing of the brava for the extra lug
cinq
http://eper.fiatforum.com/eper/navi...INT_MODE=0&EPER_CAT=SP&GUI_LANG=3&WINDOW_ID=1
brava
there almost the same except for a pkug (no 15 on brava) and how it connects
ant help would be appreciated
Ash
cinq
brava
Ash
