Hi all,
I had issues with this car. Its a Sporting. Before it use to reach 100 degress with the fan kicking in for 5 seconds and stops and so on and so forth. Now its doing it again. The radiator has been changed, water pump and coolant. When I start it in the morning white smokes comes out from the silencer and it starts to miss when I press the accelerator. When I start to move with the car, its a bit jerky when I reach 3000 rpm. When it heats up, its fine... When I stuck in traffic or I park the temperature is rising. There is no thermostat as its summer in Malta. People have been telling that the cylinder head needs to be sent to the engineers to fill it up again.
The exhaust smell is off petrol and oil at the same time, even when you leave it on idle. The oil is disappearing by months...
This dude which I was talking to use to work with Fiat and then moved on... He said that all the gaskets will be changed and the engine will be cleaned from rust and limestone...
What do you think the problem is? The cylinder head?
Most help would be appreciated.
