blackledge
- Jul 27, 2008
- 32
- 5
I have a R reg Cinq sporting (1108 sporting) that I have aquired which needs some work. I've stripped the engine (knowing it had a blown head gasket) assuming I would only need to skim the head which I could have done myself I found a dropped valve seat on cylinder No2. The head is also warped through the whole head, on the combustion side its warped by 12 thou, therefore skimming would just increase the compression ratio so much it's going to blow head gaskets even more than they already are prone to anyway. So I need another head. Am i right in thinking I need the same casting number as the one I have as there are many different options or has someone used a different casting which worked ok? Also if anyone has any heads that they are happy to let go that will suit that I can recon to get the puppy back on the road please shout me. The casting number I have is 48431614.
