ClamHunter
- Jan 30, 2009
- 14
- 2
Hi Folks,I recently bought a '96 Cinquecento Sporting that I knew to be a non runner(head gasket).The car had been sitting unused since 2003 everything looked solid and reasonably serviceable so I decided to do it up for the Girlfriend to drive.
Prior to stripping the head I had the car running,it had to be towed to get it going.At the time it wouldn't run below 2000 revs but everything appeared to be working but as expected it blew all the water out.It refused to start off the key during another attempt to get it going.Firing on the starter but not getting itself going and occasionally spitting back through the TB, so I just assumed this was the headgasket gone that was causing the problem.
The head was removed and skimmed,new gasket fitted and built back up.New belts etc,water pump, thermostat,spark plugs and radiator fitted.
When I tried to start the car it refused to start off the starter.It was firing then occasionally spitting and popping back through the TB.I automatically thought I'd made an a##e of setting the timing so I re-did it.Again and again,still getting the same result.
Last night,the car was towed and it started immediately.However it still wasn't keen on idling and was sounding rather flat!Upon stopping it it would still not start itself.Towed again, away it went!It was then taken for a run under its own power to see if it would cure itself!It would very nearly idle but just wasn't right.Unfortunately no change upon stopping and trying to start again.
Today,it still will not start itself spluttering and blowing back through the TB.
I have tried another set of coils.
Different plug leads
Even tried the old plugs back in!
Everything tried still gives the same result!
I'm not quite sure what to try next.
Anybody have any suggestions?
Could a faulty crank sensor cause this to happen?
