the temperature guage keeps raising on every journey even short ones. i am also having to fill the coolant tank every journey give or take. there is no leak however i think there is air in the pipes as the big pipe coming forward is soft when engine is running. there is no 'mayo' in the oil cap, i looked into bleeding it but cannot find the lower bleed valve, is it idential to the one over the drivers headlight? this valve is also very hard to get off should it be?
any help would be apprecieated
thanks
kimbo
thanks
kimbo
