over my time on the forum ive realised you can reset the offest by spacers yeah? which would be easier to re-set so to speak...et 22 or et 28?
ta.
ta.
Sorry -- you can't adjust a clearance which is smaller than the original offset. Think about it -- the higher the et the further in towards the car centreline the inner rim is.
Off set for a cinq S is 27.5, but fiat put 3mm spacers on the cinq sporting whichs gives ET30.5
So if you take away the 3 mm spacers, u will have something really close to et 28.
Ming
My guess is the 28s will just fit. For best handling, 3mm spacers (get some off a Sporting in a scrappy or cheap enough from FIAT) on the front only.
Yes correct! But stick some spacers at the front, it will improve handling
Ming
something which used to confuse the hell outta me with offsets is that you have to take the wheel width into concideration - however:
http://www.1010tires.com/WheelOffsetCalculator.asp
...that's a pretty useful tool - lets you work out you spacers size (if necessary) pretty accurately
added to FAQ
edit: already in FAQ
Depends what you're wanting to do, in terms of chassis dynamics keeping the same offset or running slightly smaller offsets is the way to go, this doesn't require much working out besides adding the right spacers. Unfortunately keeping the standard ET usually results in wheel/body work interaction. You can either adjust the offset (imo the 'bodge' method, however it is simple and relatively cheap) or you modify the body work (the 'correct' method but usually involves a fair amount of cash to sort out)something which used to confuse the hell outta me with offsets is that you have to take the wheel width into concideration
What tyres, offset, and where does it scrape?
