- Feb 16, 2005
- 5,983
- 988
Right....since i did the 1.4 I have had very high temps....may have been partly to do with the last fail. Now i have ported it and put some hot cams in, its even hotter.....saw 97 the other day, am not risking driving it until the temps are sorted.
I've had new water pumps, thermostats, radiator, coolant....so how can i make it better?
I have an oil cooler to try (arrives wed I hope) and drop the temps, but is ther eanything else apart form removing the stat or a bigger rad to aid cooling further?
Fans don't do anything at speed when i saw the temps....temp gauge is calibrated fine, and stat must be fully open by that point. I have tested the stat in a pan before i fitted it
Cheers,
Kristian
Cheers,
Kristian
