trigger7108
- Aug 13, 2007
- 14
- 5
Here is another fuel tank related question, when I first got the Cinq i filled the tank to full and it piddled petrol everywhere, but couldn't find where it was escaping from. (I didn't know about the fule pump cover then) When I finally got round to checking where the fuel was coming from it was coming from a pipe that comes off the front drivers side of the tank it is a small metal pipe that has a rubber pipe attached with a jubilee clip and it is coming from around the rubber pipe and joint. The Haynes manual doesn't seem to mention it. I suspect it is some form of breather pipe but i would like clarification. Also the tank is very rusty, has anybody else successfully got the tank changed free from fiat under the recall on a 93 Cinq. ( l live in the Grimsby area but work in Lincoln). If i can get it done how long does it take for them to do.
thanks in advance
Trigger
thanks in advance
Trigger
