davevandamm
Hi everyone,
could anybody help solve the problem with my girlfriends Brava?
It's a 2001 1.2 80 Sx with the 188A5.000 engine.
When driving along then braking, as the revs drop the engine cuts out, the engine management light comes on. It stays on after re-starting, but goes off sometimes, then it all starts again.
I did notice that the amber fuel light came on when it cut although the sender is still showing the tank as third full which it is.
The fuel light did go back off again a short time after.
Trouble is it did not do it all day when a mechanic friend had it, yet it did it twice when i took it too him.
He took it to have the codes read and said it had several stored which were cleared.
We noticed the engine was running a little bit cooler after the codes were cleared.
It was ok for another day then the problem started again.
Took it back for another read and was told it was probably the MAP sensor???
It had new HT leads a few weeks ago for a misfire, one of the tubes had a minute hole in it and was shorting, noticed the lead box was marked 16v Punto.
Also it passed its MOT only two days before it started to cut out.
Also it has a K+N panel air filter and was told this might be the cause, oil particles going into the throttle body??
It runs fine when your moving and idleing, it does idle lumpy when the light is on though.
Any ideas???
Many thanks,
Dave.
Any ideas???
Many thanks,
Dave.
