Hi there
As the title states, I'm having a problem with a friends brava.
It's a 51 plate Brava 1.6 elx less than 50000 on the clock.
The problem started 23rd Dec. when on their way home, the engine just died as they got home. They called me as I replaced two injectors around 2 month ago for them, since then the car has been fine until now
I tried anything and everything I could think of
Checked injectors, coils, sparks, HT leads, inertia switch, fuses basically all the easy fix parts, but in all that I wasn't getting a petrol smell and the plugs were dry, eventually I disconnected the fuel pipe from teh top of the engine bay and there was no fuel coming through at all, ignition was switched on, engine cranked, still nothing, unplugged the fuel pipe in the boot, under the cover, and got covered in fuel, but I didn't depresurize it first.
So I'm thinking either the pump has gone or the relay (whereever that is) or faulty inertia switch.
Any help would be nice as they are disabled friends and need the car A.S.A.P
Edit: I forgot to mention, they've told me that they never heard any noise from the pump since they had the car.
