As the title suggests. Can i get a transponder key with buttons for alarm cut and programmed? As the car i'm looking at only has one blue key (but does have the red).
Piccy:
Piccy:
fiatpuntosx said:As the title suggests. Can i get a transponder key with buttons for alarm cut and programmed? As the car i'm looking at only has one blue key (but does have the red).
Piccy:
jug said:i got quoted £120+VAT per remote key at 2 different fiat garages (compared to £100 for a mk2 punto sporting remote key??). get a second hand one and program it in, your car can hold 8 keys at once on immob and alarm so get more than one if you can find it. sunderland metals has one (well they did 2 weeks ago) they want a fiver for it, i didnt bother as i have 2 blues already, but wish i bought it now just in case.
jug said:if i got a second hand remote key i'd just program it into the ecu using the insert each key method, then program the remote into the alarm by holding the small button on the courtesy light and then pressing the remote button. you program the key into the immobiliser seperately to the alarm, in the same way fiat would program a new key into the car. the 4 digit code is for the fiat code system2, which wouldnt have a red key. if you have a red key you're on system1 so you dont need a 4 digit code. the red key is the ecu unlock code. they scrapped the red key for system2 prefering to hold a database of codes for UK cars only, meaning if you have an import you're screwed (my girlfriend's mk2 punto).
i've heard people talk about this accelerator pedal pressing thing before, and also the idea that an uncoded key gets coded by this process. as far as im aware thats not true, keys come precoded, the ecu learns the codes, not the other way round?
jug said:yes red key is system1. all bravo's and brava's are system1. my girlfriend's mk2 punto sporting is system2 (no red key and a little number 2 on each key blank). fiat started to hold the ecu unlock codes on system2 because uk insurance companies would not accept a code card, which is what foreign system2 cars have. my girlfriend's car is an import and the code card is lost so there is no record on earth of what the code is, i've contacted fiat uk and they put me in touch with fiat italy (i think) who confirmed that i'm stuck and there si no way to recover the code.
fiat didnt keep a register on system1, which is why the red key is important, if fiat did keep a register from system1 then a red key replacement would cost the same as any other key, but they cant make red keys because they dont have the codes. fiat told me that as well, right after i offered them money to make a red key. if they really do have the codes why havent they made a replacement red key for a single person on this forum?
my alarm accepts new remotes at the touch of a button. i could program your remote into my car in seconds. i've tried it, and i've told other people to do it and its worked for them too. it shouldnt really be that easy and i think its a security issue, but it works. the 30 arm/disarm limit is obviously wrong. try it.
