hi all .. anyone have to change camshaft position sensor on brava? looked at haynes manual which says to take off timing belt... is this necesary or can you change it without removing belt?
have injector lioght on dash.. had car plugged into diagnostics which pulled up error code for intermittent pulse sensor ( canshaft sensor)
any advice much appreciated
