FIAT Auto Specialist Team
Thread Tools
Old 17-03-2013   #1
Question Brava 1.2 16v 2000 Engine Problems
Hello,
This is my first post after looking for some advice
Recently, i have brought a fiat brava 1.2 16v.
But after driving for about 10 minutes, the car seems to have a bad idle and stall when i come to a stop.
Also while driving the vehicle the car has poor acceleration and struggles and splutters..
when the car is in neutral the car revs to 2000 rpm, then loses power and drops to 900 - 600 rpm and then engine struggles and stops
I have recently changed the spark plugs an Crank sensor...
I have no engine lights come on either..
Starting to lose my nut with it,
So any help would be greatly appreciated
Regards
Ian
iancrofty is offline Reply With Quote Quote
Old 17-03-2013   #2
varesecrazy has donated!
Re: Brava 1.2 16v 2000 Engine Problems
Quote Originally Posted by iancrofty View Post
Hello,
Regards
Ian
Hi Ian,
and welcome to the forum,
so the engine management light does not come on..?,
does it illuminate during the bulb-test at start-up..??
I think your rev-related issue is quite commonly the MAF / Throttle body,
but that often happens when first starting.. is yours only when it gets warmed through..??,
maybe do a search of "throttle-body" = in the Punto section ( same tech),
pretty sure there is a "how-to" in the guides too..!!,
Charlie
Old 18-03-2013   #3
Thanks for your reply charlie
Quote Originally Posted by varesecrazy View Post
The light does come on when the turn the engine over..
Erm.. the fault tends to happen once warmed up.. and when you press the accelerator whilst drivng, it tends to lose power
Regards Ian
Old 18-03-2013   #4
does it semm to be using a LOT of fuel..??,
just owndering if a temp sensor is dead , and the car does'nt know it's got warm and is still driving "as if the CHOKE is still on",
getting codes read is the best proper solution..,
did you read about throttle body faults..??,
Charlie
Old 18-03-2013   #5
To be honest on the fuel, i can only drive it for a couple of miles and the fault kicks in.. the after you tried to restart the engine it start fine, then the engine idle got from 1500 rpm to stall whilst not in gear...
Not had chance, do you have any you reccommend i read?
getting codes read is the best proper solution..??
Where would i got to get these?
As i have not engine or error lights come up?
Regards
Ian
Old 18-03-2013   #6
Also, to get the engine ticked over now, i have to press the accelerator
cheers
ian
Old 19-03-2013   #7
Old 19-03-2013   #8
hello charlie,
today i have cleaned out the throttle bay, still the same
also on closer inspection, the engine light does not come on... eeeek
cheers ian
Old 19-03-2013   #9
Hello Charlie,
When i started the engine, should the stepper motor open up the butterfly valve?
because it remained closed until i pulled the accelerator cable
cheers
ian
Old 21-03-2013   #10
Trader Rating: 3
ycming has donated!
IF this happens even when engine is cold. I would say it could be map sensor (if it uses the same inlet as the punto mk1 1.2 16v)
If only warm, then it could be lambda sensor!
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 22-03-2013   #11
Thanks for your reply Ming
Quote Originally Posted by ycming View Post
Could you give me a idea where i could find this sensor?
Ive not tried a new lambda sensor,
Regards
Ian
Old 23-03-2013   #12
Trader Rating: 3
ycming has donated!
again i am not sure if it's same as the punti 1.2 16v (althought) it is pretty much the same engine, it might uses a different inlet.
Mine is at the driver side near the timing belt. If you take a picture of your engine bay i could may be help point it out?
Ming
Old 26-03-2013   #13
Ming
Hello ming,
i have attached a pictured an circled what i think is the map sensor
regards
ian
Old 26-03-2013   #14
Trader Rating: 3
ycming has donated!
That is indeed the map sensor.
But only replace it, if you are getting the symptoms at all temperature.
This is the exact sensor i purchased:
http://www.ebay.co.uk/itm/FIAT-BRAVA...item4d015b48e6
Ming
Old 26-03-2013   #15
ok ming, ill give it a run about and see how she drives and update
thanks
Thread Tools
(T) HELP!! BRAVA 1.6 16V sx 2000 OVERHEATING? anthony1981 Bravo / Brava 2 20-05-2012 20:33
(T) Brava, 100 16v X reg (2000) Auto supercc Bravo / Brava 19 11-04-2008 12:14
(T) Brava 1.6 16v engine problems mr.manchester Bravo / Brava 3 19-10-2005 12:36
