I have just got my Bravo back after its been up on a bodyshops 2 post ramp for 4 months. Since ive got it back the front suspension has a light knock which wasnt there before I think its down to the suspension hanging in an un-natural position for so long.
I though i would post about it in case you can give advice or make suggestions about what to replace from experience, because im bound to miss the cause.
MOT did not pick up any faults what so ever.
On some journys i have not heard the knock at all.
I can feel a slight jolt through the steering wheel in time to the sound when turning through the entire turning range. It seems to happen more turning the steering wheel. The car does not veer or missbehave and the steering feels precise.
I was thinking about changing;
Anti roll bar drop links, (already bought polyurethane)
Anti roll bar bushes, (already bought polyurethane)
Top mounts,
wishbones,
Track Rod Ends,
Springs.
I have checked the wheel bolts are tight and had a look over things. From reading the forums ill check the subframe to chasis bolts and some bolts on the hub.
Top mounts,
wishbones,
Track Rod Ends,
Springs.
