Lamps by Post - For all your lighting needs
Thread Tools
Old 03-04-2011   #1
Brava heating problems
Hey all
Newbie here , i'm having problems with my car over heating when sat idle in traffic , it's ok for about 20 mins then over heats and temp gauge needle goes red at the top
no one really seems to know the problem but a mechanic suggested that the fan isn't kicking in? if this is the case what could be causing it not to kick in? and if its not the fan motor what is it?
any help please guys???
Neil
neilcartledge is offline Reply With Quote Quote
Old 03-04-2011   #2
Re: Brava heating problems
oh by the way make is brava 1.2 16v sx80 , 2001
Old 03-04-2011   #3
Lithuania
fan will not turn on due to bad relay, temperature sensor or due to bad wire/contacts.
On my car bravo SX100 if I disconnect temperature sensor FAN will turn on itself, when the ignition is turned on (ignition on or off, not realy remember )
Try to disconnect temperature sensor,
if no, locate and check FAN relay
pijokas is offline Reply With Quote Quote
Thread Tools
(T) Heating problems! ginger rogers Cinquecento / Seicento 7 11-06-2009 16:45
(T) Heating problems! J Birch Panda 9 19-03-2009 22:50
(T) Heating control problems k11g02 Grande Punto 11 26-01-2009 12:30
want some help with heating problems! Maze Leisure Lounge 5 26-07-2008 20:23
(T) Problems with heating girly Punto (Mk2/2b) 6 07-03-2006 06:31
