winnywood
hi guys.
ive had a little problem with my fiat brava 1.6 100 sx auto brava 2000.
the other day my wife phoned me saying the car kept cutting out and had to leave it on a car park. when i went to look at it it started fine and run great but as soon as it got warm it wouldnt tick over. revs were so low it just cut out so the next day i tryed again from cold it run ok but as the engine got warm the revs got lower and lower then cut out.
if you restart it will run ok if you keep rpm up but just cuts out as soon as you take foot of gas. so read some theads on this forum and suspected the icv so i took it off and cleaned it but no joy so i got a second hand one from scapyard and fitted it still no joy. i also replaced the air temp/pressure sensor still no different ive thought long and hard as to what it can be. ive tested the lambda sensor with a scope and got a nice alternating wave form i tryed removing the rpm sensor to see what happens but car wont start with the rpm sensor missing. ive done a compession test and got a reading of 120 psi on all cylinders the plugs have been cleaned and it appears the all are fireing ok. i ve tested the coolant temp sensor and there is no air leaks in the pipe work. ive tested the injectors got a reading of 14.7 ohms on all 4. the only way i can keep the car running is to tighten the gas pedal cable slightly so it revs at tickover to 1200 rpm. im at a loss now what it can be any ideas when driving it every thing seems great just when you slow down and stop it cuts out.
thank in advance ian.
