Posts: 7 Thanks: 0 Trader Rating: 0 | emissions fail after new lambda sensor and new cat hi,i have an x reg bravo sx 1.2 16v,it failed the mot for exhaust emissions. i replaced spark plugs,air filter,lambda sensor and cat and took it for a re-test.it again failed on emissions.i have attatched the fail sheet. could anyone help me in the right direction as to why it failed and what to do next?thanks
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat any help please?
| | #3 | ||
Posts: 16,760 Blog Entries: 10 Thanks: 177 Trader Rating: 3 | Re: emissions fail after new lambda sensor and new cat Moving to the correct section.
__________________ DISCLAIMER: "This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects." ![]() | ||
| | #4 | ||
| | Re: emissions fail after new lambda sensor and new cat How many miles on the car and when did it last have an oil & filter change? All engines burn a little oil, older ones burn more, and old oil will push up Co2 levels. Try the temperature sensor maybe? If that has failed it could be over-fuelling thinking the engine is still cold.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. Last edited by Ffoxy; 23-06-2009 at 13:05. | ||
| | #5 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat hi,thanks for the reply,the car has 106k on the clock and had an oil and filter with the mot. you mentioned the temp sensor and i now wonder if this is a problem i have created. i bought a performance chip a bout 6 months ago from ebay,it was only a few quid so i thought i'd give it a go as it said it would not harm the engine. this is the advert for it - INCREASE YOUR CARS TORQUE & BHP REDUCE 0-60MPH TIME IMPROVE RESPONSE AND FUEL ECONOMY FULLY STREET LEGAL CREATED TO INCREASE YOUR CARS HORSEPOWER AND TORQUE. THIS WILL LEAD TO YOUR ENGINE PERFORMING BETTER THEN EVER!!! You will get complete simple step by step instructions for easy install, it's really easy to fit. No special skills are required. Will fit all engine sizes and types for made after 1988, providing they are fuel injected and not turbo or not diesel. The mod itself is a small resistor that tells your engine control unit (ECU) that all of the air coming into the engine is cold and therefore dense and packed with oxygen. The ECU then takes this information and tells the injectors to fuel slightly more. This in turn makes for a more powerful detonation in the cylinders and releases the full potential of your engine. The mod will allow your engine to release its full potential, your power curve will be smoother with flat spots ironed out, your 0-60 will be quicker so you can get off the line faster and your car will experience an increase in top end speed. Also in some cases depending on how you drive, it will boost your MPG by 5%. The Mod chip will allow you to boost the power of your cars engine. Nothing else will be effected giving the car a 100% benefit. Provides 20 BHP+ more to the vehicle. i only used the chip for a few months as it didnt make much difference so i removed it and reconnected the sensor could i have damaged the car by using this,thanks.
| | #6 | ||
| | Re: emissions fail after new lambda sensor and new cat OK. Well... my car is re-mapped, because the chipping thing didnt look right to me, especially a cheap chip, all it does (if it is a chip and not a resistor) is over-fuel the motor by fooling it electronically. It might pass the MoT with the chip removed or the over-fuelling may have caused bore - wash, where oil is washed from the cylinder bores by high levels of fuel, leading to high oil burning.Can you post a pic of the "chip"? If it were my car that is exactly where I would start looking for the overfuelling and high Co2 levels. Now you have removed it,(was that just before MoT?) the ECU may have to re-learn your driving style.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. Last edited by Ffoxy; 23-06-2009 at 20:38. | ||
| | #7 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat thanks for the reply,although bore - wash is something i know nothing about and wouldnt know where to start but i do alot of work myself cos i'll give anything a go here is a pic of the "chip" it (was a cheapie from ebay) http://profile.imageshack.us/user/pk...oto0114aqx.jpgand yes it was removed just before the mot what should i look at/replace first,i appreciate your input,thaks
| | #8 | |||
Anyhow, try disconnecting you car battery overnight, that should make the ECU forget what the resistor told it to do, then the ECU will have to re-learn what it needs to know for a few miles, although how you go about that with no MoT I'm not sure.... Try the Search function using the keywords "chip" and "resistor" see what advice pops up there?Heres a link to another Thread I started on this :- http://www.fiatforum.com/leisure-lou...e-bay-0-a.html And a longer Fiat Forum discussion on the bloody things and selling or buying them. http://www.fiatforum.com/leisure-lou...eap-lol-2.html
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. Last edited by Ffoxy; 24-06-2009 at 09:51. | |||
| | #9 | ||
Posts: 154 Thanks: 2 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat well, are u usre that (air temp)sensor is reconnected correctly?
| | #10 | |||
Posts: 1,587 Thanks: 90 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat
![]() Get the chip and put it in the bin. It tricks the car into running cold start. putting more fuel in is only good on a cold engine that is not running efficiently as it will try to stall. Once the engine is warm more air can be added. The resistor tricks the car into thinking its always cold and as a result puts too much petrol in. The car thinking its in cold run mode wont try to correct the amount of air which is required for performance. instead it will run rich reducing mpg, and all the excess petrol wont always be burned it will flood the bores of the engine.
__________________ Ink Black Fiat coupe 20VT, | |||
| | #11 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat thanks for all the advice,i will disconnect the battery overnight,as for driving im really not sure,would i have to give it a good blast through all the gears or just up and down the street?and for how long?with no mot im in a catch 22. thanks again
| | #12 | |||
Yours is a perfect example of what those crap*y resistors can do to a car so Post up a warning Thread on it from your own personal experience I say. Hope you get it sorted dude...
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | |||
| | #13 | ||
Posts: 154 Thanks: 2 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat well i shuld recomend u to run car at idle for lets say 10 min then when warm, some higer revs at ~70 mph speed or so, as what is normal, just at 1 spot revving wouldnt do so much good...
| | #14 | ||
| | #15 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat
| Tags |
| help bravo in need |
| | MSH | Punto | 4 | 08-07-2008 14:40 |
| | geordieno114 | Bravo / Brava | 14 | 03-07-2008 14:39 |
| | SlinkyCinqi | Cinquecento / Seicento | 2 | 09-08-2007 22:56 |
| Drivability probs - lambda\cat hdi sensor? help plz | adzul | Scudo | 11 | 30-07-2006 23:58 |
