The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 21-06-2008   #1
Trader Rating: (0)
Indicators sometimes not working
It's odd but on some days the indicators on my Bravo are working, on other days they only work sometimes or stop completely. I push the stalk up or down and the clicking noise is not there and there is no indicator flashing on the dash.
Can anyone advise as to what the fault might be? I'm guessing the problem is somewhere round the steering column switches?
I was trying to remove the covers today. Got the bottom steering cover off easily. But the upper cover seems to be stuck or has a hidden screw which wont let it come off. http://i60.photobucket.com/albums/h1.../steering2.jpg
http://i60.photobucket.com/albums/h1.../steering1.jpg
How do i get that cover off? I dont need to remove the steering wheel first do i?
thanks
evo149 is offline
Old 21-06-2008   #2
Get busy livin'
klemster's Avatar
Trader Rating: (0)
klemster has donated! Ireland
Re: Indicators sometimes not working
This problem has come up many times before! Use the search function and you will find lots of information that should help you out!
just one result of many
Car's Thread!
Originally Posted by jug View Post
her nan bread, her pitta pouch, you know what i mean.
klemster is offline
Old 21-06-2008   #3
JoskeJTD's Avatar
Trader Rating: (0)
IIRC there are two hidden screws under neath. They are hard to spot and refit once removed but it is possible.
Sounds like a fuse or stalk fault. Faulty stalks are a common problem. Goto www.fiatboo.co.uk they have a guide for repairing faulty stalks.
Fiat Bravo Haynes Manual, Fiat Bravo & Fiat Coupe Workshop Manuals and Fiat Bravo Owners Manual on CD £5 Delivered.
JoskeJTD is offline
Old 22-06-2008   #4
Brooksy's Avatar
Trader Rating: (0)
Brooksy has donated! United Kingdom
try taking out the hazard light switch and making sure the wires are fitted properly, my mate had the same problem and this fixed it
Brooksy is offline
Old 24-06-2008   #5
Trader Rating: (0)
To remove the stalk would i need to remove the steering wheel first?
thanks
evo149 is offline
Old 24-06-2008   #6
Trader Rating: (0)
Will try this, thanks.
evo149 is offline
Old 25-06-2008   #7
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
yes i think you do. make sure you disconnect the battery first, then leave it for 15mins. do not reconnect battery until you are finished and it is all put back together.
jug is offline
Old 25-06-2008   #8
Trader Rating: (0)
might be the column switch
Did you know that a "jiffy" is a 100th of a second so next time when you say in a jiffy you best be quick
Savage is offline
Old 25-06-2008   #9
Trader Rating: (0)
Column switch, is that the one on the stalk right underneath?
Also im wondering would it be better to salvage a stalk unit from a scrappies? or just buy a new one from Fiat garage - what would the prices be for each?
My gut feeling is that the switch/stalks unit is worn out so it only works sometimes. If i buy one from a scrappies it could be the same thing again. Not sure what to do.
It's a bit of trial and error i suppose. Not sure if its the stalk, dodgy earth somewhere or faulty switch etc. I will have to wait for a day where i dont need to use the car at all before i can start taking it apart. I'm sure it will take a couple of hours to reassemble it all (hopefully).
evo149 is offline
Old 26-06-2008   #10
jug
jug's Avatar
Trader Rating: (1)
i think he means the stalk switch when he says column switch.
scrapyard will be fine, i paid £10 last time. dealer will be very expensive.
next time it wont work, try flicking and tapping the stalk, if that makes it work its a good sign that the stlak is the problem. stalk faults are common.
jug is offline
vB code is On
indicators and hazards not working WAKO Lets Talk FIAT 2 10-03-2008 13:56
Indicators working erraticaly jay_kay8 Cinquecento / Seicento 2 08-02-2008 09:35
Indicators not working carlday Marea 3 11-09-2007 10:06
My indicators have stopped working.please help ! RyanGtTurbo Punto > Technical 7 21-07-2007 19:30
Indicators Working Sometimes!! cagerrey Cinq/Sei > Technical 5 13-06-2006 16:39
