1) need to replace the passenger winmirror on my 2.0 20v hgt that is electric. only need the outside plastic bit as bits are snapped off of mine.
can i get one off a manual wingmirror? are they the same and just swap them over?
and where can you unplug the heated/electic adjustment wires that go into the mirror? are there plugs somewhere you can undo? or have i gota cut the wires then re-wire.
2) on a completely different note. ive seen a couple of bravos with the 20v turbo engines in. Is this a relatively easy transplant? what do you need to change / uprate?
does the 20v exhaust manifold fit straight onto the 20v turbo engine? what 20v turbo parts would you need from a donor? ecu and key immobiliser etc... ? does the 20v turbo engine fit into the 2.0 20v mounts, or do you need to use different mounts etc
and are you also using a diff gearbox aswel
