Time has come to replace the steel pipes on the car given the fact I've had advisories the last two MOT's for the amount of corrosion they've got. They're in a fairly shocking state.
A couple of questions:
a) Are the union fittings of a standard type? I want to avoid getting the pipes from Fiat with the fittings attached to keep it affordable.
b) Are the pipes a standard diameter; for example if I buy a roll of copper pipe from my local autofactors will it fit in the standard mounting clips?
c) Are there any issues repairing the system with copper pipes when it was originally steel?
d) If I leave any of the steel pipes in place but need to shorten them, will a normal (designed for copper?) flaring tool work on the steel pipes?
e) If you've done the job before, what are the pitfalls.
This job is the cars first close shave with the scrapyard......to get a garage to do it would write it off. The following pipes need done:
1 x master cylinder to passenger footwell join.
2 x Passenger footwell to rear compensator.
2 x Rear compensator to rear wheels
1 x Rear swingarm
Plastic coated steel pipes....why?
1 x Rear swingarm
