1.2 45500 miles flat spot when accelerate and irregular tick over all the time. no work done to it last serviced 3 months ago but problem was before then also it only just past emissions on last mot.engine?
milage?
rpm flat spot occurs at?
when last serviced?
tick over erratic when cold or warm or both?
had any work done recently?
it happens all the time in every gear no matter what the rpm.
similar prob myself..only minor....excellerating in each gear between 1000- 2500 is the flat spot, then near to the point the turbo kicks in and its fine!!! ( 1.9 TD 100 SX 99V..)
would taking off the NEG lead for 30 mins approx help to reset codes? thought this would be the first and easiest way???
ONE problem i only have two blue keys and NO red key. if i take off neg lead will i be able to start the car again?????
imo it sounds like you are describing turbo leg.
Yeah that flat spot is called owning a diesel
Don't be afraid of driving a Fiat diesel engine hard. Don't try to drive it so you just drop in the next gear at 1000rpm.. You get best efficiency when the turbo is forcing air into the engine. How long have you been driving the car?
This might sound daft but how does the diesel burn if the plugs dont operate whilst engine runs? ( used to petrol cars.)
