shunter2150
Hi guys, Hope you can help me.
I have recently bought a Fiat Brava SX80, 1242cc on a 51 plate (late 2001) 53000 on the clock.
The problem is that as I pull up at lights or a junction the engine stalls. (orange engine management light is on permanently)
Otherwise, it runs perfectly. If it`s possible, a blip on the throttle as soon as the clutch is depressed stops it stalling, but that can be difficult sometimes in traffic.
Reading other threads on this wonderful forum gave me some ideas, but I don`t really understand these modern vehicle electronics.
Things I`ve tried:
Removed and cleaned crank sensor. - no effect
checked for obvious signs of air leaks - none found
General check of wiring and connectors for corrosion - nothing found
Reset EMU by disconnecting battery neg for 1hour reconnecting and leaving on tick over for 5mins then restarting and driving normally. - Light went out and stayed off for about 16miles before problem re-occurred and stalling returned.
Took car for diagnosis at local garage (they said they could do this OK) that showed that the MAP sensor was faulty so had it replaced (cost of everything £102.25) - was OK for about 5 miles then problem re-occurred.(the garage said the map sensor was the only fault shown so can`t understand why it didn`t work)
After reading more posts here, it seems that by resetting the EMU I now need to have the throttle position sensor reset by a main dealer,(tick over is 800 rpm) but was wondering if you could help narrow down the problem or give a better idea of what might actually fix it. I can`t afford to keep replacing bits in the hope that that cures it.
Any help would be very much appreciated
Regards
Things I`ve tried:
Regards
