Good evening. Mr. Modivator here. Murf has been getting hard to start from cold and showing the exact symptoms that the Haynes manual says points to "blocked starter jets, passages or valve".
So the carb is coming off anyway for a good look at those areas.
Meanwhile I have a 28IMB1 fitted to the 594 engine, which I have had working. So partly as an exercise to double-check and eliminate other reasons for the issue and partly for fun, I'm going to try the bigger carb.
I've checked the specs and apart from the main jet, which is slightly bigger, there isn't much difference from the 26. There is a need to swap one of the carburettor mounting studs, which is longer and the intake elbow will need the later type intake tube, but apart from that it's a straight swap.
To the question, has anyone done this and WILL I GO EVEN FASTER?
