Is that new and old? If so which is which. EPDM hose is the correct one to use.
Oh I have just read the picture. I assume the top one is the one you originally had?
When springs sag, they do so, both under load and with no load. So if you pop them out and measure, you'll know if it's solely down to the rear springs.
cheers, Steve
Either spring sag or location on swingarm? There's an indentation that you butt the first coil up against and this prevents the spring from turning. You should be able to check in situ
The springs were new when I restored. The first thing I checked was the locating stop, but I will double check next week....which reminds me, I did order a checker pattern sunroof :what:
Started modding eh, whatever's next. You could lower Murphio and put on some up rated springs to sort out his wonky backend
....I will be going further..there have been some old stock, FIAT rear mud flaps taunting me on EBay for ages. I am fed up of Murf getting a dirty bottom on his winter meanderings
I've bought them and as they're predominantly white (a bit daft you say?), there will be a bit of a thematic match with the roof.
Maybe they'll also hide his squinty rear.
Peter,
When if fitted my rear springs I noticed one side is easier to fit than the other.
If I remember correctly the ns one you can fit it in slightly the wrong position and this may make it sit slightly higher.
I also had to renew my exhaust as the other one had a little patina to it.
I've had another look at the spring and it's all properly seated...baffling.
I've made myself another challenge now the mud flaps have arrived. Whilst they are very nice, I'm not sure they are specifically for a 500. So the "fitted in 2 minutes" on the label turns out to be rubbish. A job for a quiet, sunny day. Look at the original price...I think that might have been quite expensive pre-1971.
It is a bit loud, I would stick with black for the roof.
H A
