Hello everyone. I am the very happy owner of a 1972 500L that I had been driving for about 2 years now with no issues. All of a sudden it started being starved of fuel. It idles fine but when I mash the accelerator quickly it wants to shut off. If I accelerate VERY slowly it will putter on up to higher revs.
First thing I did was change the fuel filter but the same was still happening. I then changed all of the hoses in case one was clogged and even inspected the few metal lines that it has.
I then purchased a new fuel pump but still the same. At this point I am thinking that the carb needs a rebuild. This is where I am needing a sleuth...
it does not have the typical Weber IBM 26 carb. What it does have is a Dellorto FRG 28 carb that when I try to look for a rebuild kit online all I am getting is newer style carbs and even ones for Vespas. The person that I acquired the car from also gave me a 500R Weber 28 IMB carb but when I install that one the car wont run at all because it floods. It appears that at some point someone sheared off the fuel return nipple on the carb but I am not even sure if that nipple would be useful on this car since I don't even see a return line on the fuel tank. I don't know where else to look. I am going thru Fiat driving withdraws. Any help or advise is welcome. Thanks in advance
