You must remember some of the old Triumph's Sean, like the Herald, GT6 and Vitesse. They had pretty positive camber to say the least. As they had a leaf spring at the back, they did have a tendency when cornering at speed to almost collapse in on themselves.
It could be quite hairy to say the least, it happened to me once. The back end hit a bump and as the car was lowered with some pretty hard Koni shocks on it, all the weight went from the back end drive wheels, they tucked themselves in and it came down hard and hit the end stops, the back end just started squirming all over the place. It's one of those situations where if you hit the brakes it will just make it worse, you just have drive through it. But it did scare the life out of me.
