I have been struggling with the bleeding, bleeding job on the Fiat, and that is in spite of buying an all singing and dancing vacuum bleeder...helpful hint: PTFE tape on the threads of the bleed nipples.
I think it's now done but the pedal travels too far before all four brakes are activated; I don't think that it's sponginess through air.
The thing is that there is reliable information saying that all wheel cylinders should be the same size but I know that the fronts I was supplied with are a bigger diameter without the rears being smaller (as far as I know) than standard.
Does anyone know if this means the master cylinder may not have enough capacity and this would give the symptoms i am experiencing?
