Pete145
Member
- Jun 2, 2014
- 288
- 85
Well, not a good day!
Third thread and this is by far the most serious.
So, I thought I'd finally get my hands dirty today and start with a simple oil change (the car needed a 'run in' oil change after 300 miles, as the engine was essentially new following the work that had been done on it).
I followed the simple procedure easily enough, using the Castrol Classic oil that was recommended by fellow owners club members. My car seems to run better with more oil in than less, so I filled it up to the MAX line (perhaps even a tad over, but I didn't think it was over enough to worry about draining some out).
All good, however on the test drive the engine bay started billowing smoke as the engine and exhaust were covered in oil. The dipstick had also pushed out.
I limped it home, repeated the entire process with LESS oil (just above the minimum line), wiped the engine clean of oil and, the same result. After a short test drive the engine and exhaust were covered in new oil and was billowing smoke.
I suspect that I may have caused a problem by adding too much oil in the first place.
What would be the most common issue for me to look for? Would a gasket blow as a consequence of this?
