Same as last time Damian,
Glass bead
Soda blasting gets the paint off but is not that good at removing rust.
The glass bead blasting was excellent last time. Admittingly I removed virtually all the rusty panels before and only left them with the light rust.
Trouble is I spent ages cleaning rust up, but this time I'm letting them do all the hard work. I have removed the worst panels that I know I will be replacing, cut out the worst of the rust and then they can get the shell clean. It will be nicer to work on & I can weld through the primer they put on.
Really looking forward to getting it back.
Also sending off the following:
Front hub uprights
front drums
rear swinging arms
rear springs
front and rear brake back plates
rear brake drums
gear stick, bracket & the long arm
gearbox support
boot lid
Sump
air intake tube (separate from the car on the D)
Brake & clutch pedal
My blast cabinet is ok for small stuff, but as you know it takes ages, its messy and my compressor doesn't have the same air pressure as they do.
They really get rid of the rust.
Leaves me with just the nice bits to do.
