Need words of wisdom..
got a complex VW to work through
Experiences please
Experiences please
Good luck with it all Charlie, I'm very interested to hear what you find so please do let us all know how it turns out.Back to basics..and try VCDS to 'see ' what the various live data feeds can tell us
Enjoy your break !!
I'm late to this but what concerns me is the cause of the timing errors that have been found.Good luck with it all Charlie, I'm very interested to hear what you find so please do let us all know how it turns out.
"enjoy your break" Yes we're down here in the West Country near Barnstaple on one of our trips to visit Mrs J's sister and our older boy has moved his family into our house "for the duration" so they can enjoy a bit of "city life" whilst we are away - which is nice because it means I don't have to be concerned about the house while we are away.
We came down earlier in the week and had a good journey. No hold ups but heavy traffic in the midlands - which always makes me a little nervous - and only the occasional "lunatic". The top end of our journey is down the A702 to the M74, a twisty but quite fast main road where I was able to asses how the new Falken tyres performed. Have to say I'm very pleased with them. The car felt much more "planted" than it ever did on the old Bridgestones and grips very well indeed on the corners. I continue to be impressed by the balance job Steven did on them as there is absolutely no hint of a tremor through the wheel at any speed.
My daughter and her husband and family have been visiting folk in the lake district and are traveling down today to spend Easter here with us in Devon. Got an email from her about a couple of hours ago saying "We set off at about 10am. M6 south closed. Trying to detour. Will keep you informed" and I've not heard from her since. Oh so glad we traveled earlier in the week!
Kind regards and have a happy Easter - Go easy on the Easter eggs!
Jock
You make a very good point Robert. Scanners like VAG-COM (now known as VCDS) and MES let you see what the car's ECU thinks is going on and this doesn't necessarily mean you're seeing "true" values (That makes me think of Eric and Ernie and their famous Andre Previn routine with the piano). It can be very useful to know what the ECU thinks is going on though, especially if you know what it actually should be seeing. An oscilloscope however displays true values because you are sampling directly by back probing connectors etc. I can't justify the cost of the Pico for home use but I've looked a few times at the Far Eastern options. Probably I'm going to be too old and infirm before I make my mind up for it to be worth my while buying one though, much as I covet one.I'm late to this but what concerns me is the cause of the timing errors that have been found.
It could be a mechanical fault. VCDS is very good. I used to use VagCom on my Audi S4 (2.7 twin turbo).
See if you can find an auto electrician near you the uses Pico Automotive diagnostics. Thes ae oscillocope based test that g back to fundamentala rather than what the ECU "thinks" is going on. For exmple relative compression check just by clipping a sensor on the battery lead and ctanking the engine.
Robert G8RPI
@varesecrazy @Pugglt Auld Jock Just found this vid
Nice comparison of VCDS and OBDEleven.
With just the one VAG car, and not needing to do much other than an occasional oil change, if the miles go high enough in a year, I went with ODBEleven. If I was doing as much with this, or more VAG vehicles, I'd be happy to invest in VCDS.
Charlie, you'll see from about 20 minutes in, he shows how live data can be read using OBDEleven. If you want to borrow and play with this, that's easy, it is a dongle, and a tablet.
