Sure will - go try itWill it open the Sunroof and the blind bit too if I hold the button or just the actual sunroof? That's a cool feature even if it isn't both![]()
i think its to reset the fuel cut off if it comes in at all
Did you have the front wipers on at the same time? it automatically turns the rear wiper on when you select reverse until you go back into neutral or select another gear
The upper glove box was an amazing revelation for me!
Do we all know that under the drivers side mats (both of them) is a little compartment for hiding keys and money etc?
Depends on relative position compared to car.
Very weak from the rear but seems to be at its best from above.
Quite impressive when in the office above the car park and you're able to shut the sky-roof![]()
Dont know if any one remebers top gear with the key fob to the head test, its actually reaches double the distance if you put your key to your head and look at the car , try it!!!
Yes; that's a completely standard feature on all 5 doors (due to sliding rear seats) and I think the MW has an even fancier design.they are not sun blinds,if I push the rear seats forward towards the front seats there are black blinds that extend from the parcel shelf to the rear seats so the extended boot is covered for security,he said never seen it before but to me its a fairly obvious design to me.
