If you notice any data that is wrong or would like to add anything please let me know via PM
Q. Which models are fitted with a front armrest as standard?
A. Active Sport and Dynamic
Q. Which models have ESP with Hill Holder as standard?
A. Sport model only. However it is an option for all other models.
Q. Which models have Blue&Me as standard?
A. Dynamic and Sport models. However it is an option for Active and Active Sport models
Q. What are the quoted 0-62mph times?
A: 1.4 16v 90 - 12.5seconds
1.4 16v 120 T-Jet - 9.6 seconds
1.4 16v 150 T-Jet - 8.5 seconds
1.4 16v 150 T-Jet Sport - 8.2 seconds
1.6 105 M-Jet - 11.3 seconds
1.9 120 M-Jet - 10.5 seconds
1.9 16v 150 M-Jet - 9 seconds
Q. What models have Cruise Control as standard?
A. Dynamic and Sport, although it is an option for the rest of the range.
Q. Does the Bravo have deadlocks?
A. Yes
Q. What are the Bravo wiper sizes?
A. 24" and 18"
Q: Anything related to skydome
A: https://www.fiatforum.com/bravo/162015-skydome-q.html
Q: What are Bravo rim and tyre parameters?
A:
1.4 16V:
Rim: 6J x 15 ET 31.5
Standard tyre: 195/65 R15 91H
Snow tyre: 195/65 R15 91T (M+S)
Rim: 7J x 16 ET 31
Standard tyre: 205/55 R16 91H
Snow tyre: 205/55 R16 91T (M+S)
Rim: 7J x 17 ET 31
Standard tyre: 225/45 R17 91V
Snow tyre: 225/45 R17 91T (M+S)
1.4 T-Jet 120, 1.6 Multijet, 1.9 Multijet 8V:
Rim: 7J x 16 ET 31
Rim: 7J x 17 ET 31
Rim: 71/2 J x 18 ET 35
Standard tyre: 225/40 R18 92V REINFORCED
Snow tyre: 225/40 R18 92T (M+S)
1.4 T-Jet 150, 1.9 Multijet 16V, 2.0 Multijet:
Standard tyre: 195/65 R15 91V
Rim: 7J x 16 ET 31
Standard tyre: 205/55 R16 91V
Rim: 7J x 17 ET 31
Common rim parameters:
Number of holes: 4
PCD: 98 (100 only with wobble bolts)
Centre bore: 58.1
Q. What are the correct Tyre pressures?
A.
![Tyre Pressures.JPG Tyre Pressures.JPG](https://cdn.fiatforum.com/data/attachments/85/85902-7fd03acf293d4bbc5dc52b01d0bdd024.jpg)
Q. Can I blank off my EGR valve?
A. Yes, however you will need to find a garage to delete the EGR valve from the ECU otherwise it will just flag up errors. There are sensors which measure the flow of gasses through the EGR valve, these also control the fuel/Air mixture so if you try and blank it off without removing it from the ECU you'll get errors and more than likely a rough running engine.
Note: MultiECUScan can't delete the EGR valve
Q. How can I remove and clean my EGR valve?
A. Check out this post over on Alfa Owner, there is a rather good guide on removing, stripping down and fixing an EGR valve: http://www.alfaowner.com/Forum/alfa...ix-the-egr-valve-1-9jtd-pdf-instructions.html
(Please note this guide is for the 1.9 16v Diesel and may differ on other engines.)
Q. I would like to remove my DPF, how do I do this?
A. Well first of all if you are in the UK it is now law for an MOT center to test for a DPF, if your car was built with one and it has been removed it will fail its MOT (source: https://www.gov.uk/government/news/new-rules-for-mot-to-test-for-diesel-particulate-filter). If you live outside of the UK double check your country doesn't have a law similar to the UK. If it is legal to have the DPF removed then you should seek expert advise, there is plenty of companies out there who can provide you the service of removing a DPF.
A. Yes
A. 24" and 18"
A:
1.4 16V:
Rim: 7J x 16 ET 31
Rim: 7J x 17 ET 31
Rim: 7J x 16 ET 31
Rim: 7J x 17 ET 31
Rim: 7J x 16 ET 31
Rim: 7J x 17 ET 31
Number of holes: 4
Centre bore: 58.1
A.
