Technical Turn and start problem , when turning key to start ,only dash board lights go on .
Anwarm2m
Atlantis
When I turn key to start my fiat palio weekend wagon , only dash board lights turns on ,and no start ,nothing wrong with battery , don't k ow where to find starter to check for loose ends or connectors to starter
Hi 🙂
Do the dash lights Dim at all?,
If they Dim, suspect a high power draw
Like a bad starter..
At this stage worth adding a 2nd Battery to Chassis earth connection, (you may find the factory black cable has failed internally) 😉
Hi 🙂
Hi thanks ,much appreciated,but can it also maybe be a live wire that came loose and touching the body ,cause it makes a very loud noise when turning
Loud noise,
Didn't mention that earlier.. 🤔
Often that will be the starter not engaging properly, so again check earth cable battery to chassis
If the starter isn't getting Lots of battery power it can do this
