Hi all,
I posted a similar thread on Fiat Spider.com but I like hearing multiple perspectives and have had good guidance here (Thanks bugsymike if you see this
My last post on this thread I was talking about aligning timing marks, but I have decided I may want to do some engine work as it was burning lots of oil when it last ran. I know I at least want to remove the head to see if valves bent because I'm paranoid I have bent the valves. It has not run in about 30 years so I have not compression tested it; I am in the process of getting it to run.
The oil leak is to my best knowledge going to be coming from the piston rings, but I am not sure. I have never rebuilt an engine before; from what I read the FIAT twin cam is pretty simple. Can anyone confirm or provide some insight onto the skill level of an engine rebuild? Any advice for a rebuild at all would be great!
If I were to do an engine rebuild, I think I would want to increase my CR. I have read about fitting older engine heads onto the 1995 cc engine but can anyone attest to this? I am also thinking about higher CR pistons but that seems like a whole other can of worms.
I think I will look at rebuilding my heads but aside from the oil leak, I do not really have a reason to rebuild my engine. I am just at a crossroad as this is probably the closest I'd be to removing the engine and I'm not looking to take everything off after putting it all back on.
TLDR
My engine burnt oil when it last ran and my valves may be bent but I am not sure. Is it worth my time to give it a refresh now or not?
Thanks guys!
Michael
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
TLDR
Thanks guys!
Michael
