shaun200765
Quick query please, goodness knows if anyone knows the answer to this one? Deep breath..I'm looking to use the relayed output from my cars front fogs feed for a different project (all revealed soon if/when it works).
I bought a second hand lights control panel from Ebay, used the solder on surface mount momentary switch and resistor from that to populate the panel from mine. The blank button has two plastic webs that you need to cut in order for the button to work as it should. So far so good, with the side lights on the led front fogs indicator lights up on dash when pressed with side/main lights on.
The engine bay fuse/relay box next, R14 is for front fogs, rear demist relay liberated for this, identical fit. But no operation, every fuse is there that's appropriate and ive measured a 12v feed from ign live. Query is, my car was never fitted with front fogs from the factory, does anyone know if it needs to be enabled as a proxy alignment please? My eternal gratitude for any help![Slightly smiling face :slight_smile: 🙂](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
