Afternoon, just wanted to see if anyone else has had the bad experience that i have tyring to replace the head unit in my Van
So to start I brought one of these A-Sure Head unit, unit came and i pulled out the old single din unit i had in the dash which worked but not very well
I wanted an upgrade to have Android Auto and DAB+ etc
So after fitting the replacement plastic panel, i set about wiring up the system, all the wires fitted and i attempted to turn on the unit but nothing happened.
checked the wires, and all looked good Check the Cambus is connected and then i got the multimeter out to make sure there is power, There was 12v across the fuse
Now I connected with the seller who asked me to switch one of the cables in the loom block, I did this and again nothing, checked the voltage, and again it was all good
so now I'm back and forth with the seller, they are trying to help and they offer a new wiring block, This takes a week to arrive and again nothing happens
but this time i got the paperclip out and tried a reset, the unit then showed life, and after 5mins came alive, so there's me thinking was it me but then I noticed none of the buttons on the unit were responding.
The seller now sends me a replacement unit, i plugin, and again nothing happens
So as anyone else had this experience with these units? and could the Cambus be the problem I am stumped.
