Hello again
can anyone shed any light (pun ignorable as you prefer) on some odd issues that I am experiencing with the car, please?
Just the other day (after a bit of a lay up over the winter) I noticed that I was getting a glow from both the door courtesy lamps even with the doors closed fully. The glow is visible only really at night. Then the day after, the problem was gone. It is no doubt bound to return. Anyone else had this? I do not think the door switches are the issue but will clean them up.
Looking at the Haynes wiring diagram for the 1500cc car, I am not convinced that it is accurate, however the items in the circuit are the door plunger switches, courtesy lamps control switch and courtesy lamp timer.
It may be that there is a poor connection at either of the latter two or an internal component problem. However, what do the courtesy lamps control switch and courtesy lamp timer look like and where are they?
My problems with the hazard switch and indicators (explained below) may not seem to be linked to the courtesy lamp problem but the circuit of the courtesy lamps appear to go through the connector behind the hazard switch; which I have had apart and cleaned without improving the issues.
Turning to the hazard switch and indicators, the problem here is that although the indicators operate well in the usual course of things, if after I operate the hazards with the indicator stalk in neutral position, I then try to use the indicators left or right, they fail to operate at all.
Taking the hazard switch out and moving the connector back a little restores the indicators...until I next use the hazard switch. Anyone else have this?
Do we think that this is all due to something amiss with the actual connectors in the connector block (as I do), or some issue with the switch operation or something else.
NB the proper operation of the courtesy lamps returned before the problem with the indicators re-occurred.
Thanks in advance.
RDS
Thanks in advance.
RDS
